let me get this right (flexplate)
Old Dec 26, 2001 | 09:48 PM
88NOSTA's Avatar
i have a 1979 350 going into a 1988 ta! now i have the 305 flexplate will that work?
Old Dec 26, 2001 | 10:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No. Your 88 model flex plate is for a 1-piece-rear-main-seal crank, but thate motor is a 2-piece RMS.
The 350's flex plate probab'y won't work either, because it's almost certainly the 14" 168-tooth variety. You probably need the 153-tooth 12¾" flavor.
It might be possible to use the larger flex plate, if you change the starter to the appropriate one. This interferes with some wxhaust systems on these cars though, because the center of the starter is 5/8" farther out, plus the starter is larger. But it could conceivably happen.
The sure thing is to get the right flex plate, though. Get the one for a 82-85 305.
Old Dec 27, 2001 | 08:38 AM
88NOSTA's Avatar
cool ok thank you!
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
