non roller cam to roller cam
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
so ive got an 87 one piece block with provisions for a roller cam but not drilled and tapped for the retainer plate on the nose or the spider for the lifters. anybody ever drill and tap these to use a roller cam in a block like this?
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: non roller cam to roller cam
just use a cam button..no need for all that stuff..
if you order a comp cam custom cam..get a billet cam with a cast gear..then there is no need for a bronze gear..on the dizz
Engine: 383
Engine: 4++,350 & 305 CIs
The block is easy to drill and tap. Don't be scared, have it.
Engine: 383
Sounds good and what I figured. Doing it for a friend wants to build a 383 stroker and already has a good top end.
tapwr
Jul 20, 2017 03:40 PM
m300slr
Sep 2, 2016 08:04 PM
