383 build. Heavy pics.
Old Sep 30, 2016 | 05:54 PM
  #51
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: 383 build. Heavy pics.
7.4 length. You can see I am getting closer to the intake but loosing my 90 to valve quickly.
Full lift.
Although I am getting closer to the center of the valve face, You can see my sweep is getting wider. Pretty much doubled.
.045
base... No lift.
Half lift.
Full lift.
Now mind you, this is the length PR I ordered for my first build, basing length solely off centering sweep on valve face. I did a good job but look at that sweep!! .070... more than 3x as much.
So based on my findings, I am going to look for a PR as close to 7.5, tip to tip, as I can.
What are your guys thoughts? Please feel free to comment.
-D
Old Oct 1, 2016 | 06:23 AM
  #52
skinny z's Avatar
First off, keep in mind that the MOST important aspect of valve train geometry to to be at 90 degrees to the valve stem at mid-lift. This is with a line drawn through the centre line axis' of the trunnion and roller tip.
Looks like that's the direction you're heading. Don't fall into the trap of compromising that target in an attempt to centre the contact patch.
Now, what I see is that you haven't taken any measurements.
Try this (if you will): And you can use the running springs for greater accuracy (maybe .040" in the difference here!) however you wont be able to do a sweep with your hydraulic lifter so just beware.
Anyway, with the lifter on the base circle, and I see that your retainer has a nice flat top side (or so it appears from your pictures), use a straight edge of some sort and extend the plane of the retainer top side surface so that it passes by the trunnion axis. Measure from this surface to the centre of the trunnion. Now do the same with the roller tip axis. Subtract the trunnion value from the axis value. The result should equal EXACTLY the half lift measurement. Remember that your half lift is the cam lobe lift times the 1.52 ratio of your rocker. Don't use the cam card spec as it may not use a 1.52 factor. Measuring is best.
It's good to see the nice narrow sweep of your contact patch as this is an indicator of good VGT.
I'd be interested to see if there are any differences between your method and the one I've described.
By the way, in your previous build with the 7.3" pushrod, did THAT build have the excessively wide sweep or was that just an experiment using that pushrod in this engine combo? Curious.
By the way, Comp has pushrods listed in .050" increments.
Old Oct 1, 2016 | 01:25 PM
  #53
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
I used a Mitutoyo dial indicator and a caliper to do all my measuring. I started off finding what length pr I would need to achieve 90* to the valve. This came out to be 7.6" long. That had my roller tip way out to the exhaust side. So from there I shortened my push rod in .100 increments to get roller tip towards the intake some, but with being 90* to valve at half lift my major focus. I worked this with 4 different length push rods, recording sweep, sweep location and my major focus, being 90* to valve at half lift. My findings told me that a 7.5" push rod gave the best results. Its a few degrees from being 90* to the valve, sweep is very narrow, and roller tip pushes on valve face in what I feel will be an ok place from reading and seeing MANY other set ups with achieving VTG.
The pictures above may seem confusing as there are several, with several different length push rods.
Old Oct 1, 2016 | 01:27 PM
  #54
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Skinny, The 7.3 push rods were set up on first build with sweep being centered on valve tip the main focus.
Old Oct 1, 2016 | 10:15 PM
  #55
skinny z's Avatar
No confusion with the pictures. I can see your approach very well. What I was asking for is not the traditional method of dialling in the geometry but rather the approach from the paper I provided a link to.
What's unfortunate is that in a lot of cases, yours and mine included, is that we're forced to choose between optimum geometry and the contact sweep riding off the valve tip. You had to back off from being closer to 90 degrees by shortening the pushrod when the best case scenario would have been having the valve further away. That's the compromise with these aftermarket parts and why the big boys move on to a shaft mounted system. What I can't say definitively is how much we give up in terms of performance and longevity. You'll have to forgive me if I seem to be bordering on the excessive. I just hate replacing valve guides although admittedly, my most recent result was from inattention. The other time was my misguided thinking in getting the sweep centred although I've learned (as you indicate you have too) that's not the approach at all.
Some shops go so far as to mill off the rocker studs and relocate the mounting holes inboard so the VGT can be corrected.
That's also why I moved on to Crower's backset rockers.
I probably go back in this off season and revisit my own setup again.
Old Oct 4, 2016 | 06:42 PM
  #56
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Update-
Motor is together!! I sand blasted my intake, debated on shooting it with clear but decided not to. Next step is going through my carb and cleaning up valve covers. I cant believe what a nice set costs!!??!! I need to talk to dyno guy to see what all he wants me to put on. I'm guessing not much. So I hope to have carb, valve covers all done this weekend. Dyno maybe end of month. Need to save up some cash.
Pics soon.
-D
Old Oct 4, 2016 | 07:16 PM
  #57
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Old Oct 15, 2016 | 07:54 PM
  #58
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Tapping my foot, patiently waiting for dyno results.....................
Old Oct 17, 2016 | 09:58 AM
  #59
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
post up when you get the results
Old Oct 17, 2016 | 01:46 PM
  #60
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
ME too! Just gotta save a few more bucks. Still dont know what oil I'm going to run... I will post results and video!! Untill then I'm kinda at a idle. I'm going to make a nice thick back alunimum cover for my water pump. Weiand G team. It keeps blowing the seal for some reason from first build last time I had engine running. Also looking at carb kits. They have a master hp kit for 120 bucks that comes with everything. different cams and squirters for driving adjustments....
I plan on having some numbers and video by the end of the month for you all. "fingers crossed"
-D
Old Oct 17, 2016 | 01:47 PM
  #61
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
I will for sure. Video too. Just a couple more weeks!
-D
Old Oct 21, 2016 | 06:50 PM
  #62
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Engine ****.
Stay tuned for dyno results soon!
Old Oct 31, 2016 | 05:09 PM
  #63
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Alright guys. This sat at 11 is dyno day. I'm nervous and excited as all heck. Going to pick up some royal purple breakin oil tonight and finish rebuilding carb tomorrow.
Stay tuned!!
Old Oct 31, 2016 | 05:10 PM
  #64
Car: 1986 IROC Z28
Stay tuned!!
'bout time!
Old Oct 31, 2016 | 05:50 PM
  #65
skinny z's Avatar
Don't forget to shoot some video.
Old Nov 2, 2016 | 06:57 PM
  #66
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
'bout time!
I know!!
Old Nov 2, 2016 | 07:00 PM
  #67
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
For sure. Was just asking my brother if I can use his video camera. I'd like to set it up in the engine room and also get some video from the control room. So if all goes as planned, I should have results up and posted sat evening!
Old Nov 5, 2016 | 08:51 PM
  #68
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Started a new thread....... "383 Dyno Results"
Old Nov 7, 2016 | 10:54 AM
  #69
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
wheres the link?
Old Nov 7, 2016 | 10:59 AM
  #70
skinny z's Avatar
https://www.thirdgen.org/forums/tech...o-results.html
project89
Jun 13, 2008 09:48 PM
Stekman
Mar 15, 2005 11:09 AM
breathment
Aug 9, 2002 11:51 PM
breathment
Mar 26, 2002 12:20 AM
un4givin89
Mar 15, 2002 11:43 AM
