Radiator
Old Dec 30, 2001 | 12:17 AM
1984Firebird502's Avatar
Radiator
I've heard a lot about this but I just want to make sure.
First off:
Do you think my v6 T5 would do well up against my moderate 305? It's nothing special, I would say prob as much power as stock trans am's 305. I mean, if I didn't drive it hard (yeah right) etc. . .
Second:
Is it NESSACARY I change raditors to a v8 one?
DON'T TELL ME TO SEARCH ARCHIVES! I have .
Old Dec 30, 2001 | 01:18 AM
Guest
Guest
Posts: n/a
The radiator you have is probably the same deal, I'm not positive what they used in a V6 but I dont recall it being different. The typical radiator in a V8 car is made of aluminum with plastic end caps, and the rows in the radiator are 1" wide. If yours matches that, you are good to go.
Old Dec 30, 2001 | 07:12 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
The v-6 is different. the hoses connect on opposite sides. Go to the jy and get one off of a v-8 it will bolt right in.
Old Dec 30, 2001 | 02:05 PM
Guest
Guest
Posts: n/a
Well now, doesnt that suck!
I guess you are in for a new radiator.
Old Dec 30, 2001 | 04:59 PM
Thanks. Ok then, how about the T5? I know about the bell housing etc but it'll work right? This isn't going to be a street car, just something I can drive to the grocery store in college twice a week with.
Old Dec 30, 2001 | 07:00 PM
87RS402's Avatar
In regards to the T-5, the clutch's and input shafts are different . You'd have to have a V-6 disc hub put into a V-8 disc for it to work correctly. Otherwise you'd be running a 9.something" disc with a 10.4" pressureplate and flywheel.
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
