Bigger oil pan
Old Aug 4, 2017 | 07:08 PM
ItalianIroc-Z's Avatar
Bigger oil pan
guys i am thinking of putting a moroso 7.5L oil pan on my 427 but will not quite fit in my third gen without griding the K member is it that much a better improvement for the engine compare to a 5. L pan
thanks
Old Sep 28, 2017 | 05:19 PM
Jeremy85's Avatar
Car: '85 Camaro
Engine: LG4
Transmission: 4L80E
Axle/Gears: 3.42:1
Re: Bigger oil pan
Consider an Accusump instead. Then you could run a half quart lower to reduce wind age and aeration. Also, if you do pull the engine, someone makes a splash shield to keep the oil from sloshing up the back of the pan onto the cranked rods under hard acceleration, it's just a little piece of rain steel, runs like $5.
