305 Parts on a 350
305 Parts on a 350
I am swapping out a 305 for a 350 2-bolt main in an '84 Z28, and believe that the 305 and 350 have the same stroke. All I have is the 350 block so am I able to use the crankshaft & connecting rods from the 305 in the 350?
Thank you.
Kevin
Thank you.
Kevin
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 305 Parts on a 350
the 305 & 350 cranks start out the same at the factory,but 305 crank will have more weight drilled out in order to properly balance the lighter 305 pistons-so balance will be way off using stock-ish 350 pistons...
juanillox8
Exterior Parts for Sale
39
Sep 26, 2010 04:52 PM
badwolf76
23
Nov 16, 2008 07:13 PM
