ZZ4 Conversion for 89 RS
Old Jan 7, 2002 | 06:32 PM
Nickerz's Avatar
Will there be any problems installing from a 305 LO3 with this kit? Its not intended for it but I cant see too many problems besides emission compliance.
-Nick
Old Jan 8, 2002 | 12:14 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
check out the website in my signature.
i did a 350 HO but a lot of the info will be the same....
-brian
Old Jan 8, 2002 | 04:06 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I had talked to SDPC about the same thing. They told me the cam had too much duration for the TBI, I explained the custom chip idea and they said no.......I purcased their TBI specific motor with 310 hp and 410 ft./lb ( I think it will have more HP than that) I have not started her up yet but we are getting close
Brian
Old Jan 8, 2002 | 07:06 PM
Nickerz's Avatar
I didnt plan on using the TBI, I planned on using the carb anyways. So it doesnt come with a carb? What components would I need to purchase for it to work? And why does it say the 350HO? Is it the same thing? I ask this cause I plan on adding a whipple supercharger on top of that in a year or so for a nice *** 518hp and 544lb/ft.
-Nick
Old Jan 8, 2002 | 07:21 PM
The ZZ4 is an awesome motor however the comp ratio is a little high for a Supercharger. THe ZZ4 will sit in and run all you need is a Carb. (750 cfm) The Ho motor has cast heads and a little less power however the comp ratio may be closer to supercharger range.
Old Jan 9, 2002 | 07:39 AM
Nickerz's Avatar
well im assuming they put the engineering into the kit for it to be safe. From what I have heard whipple is a pretty damn good company. And the crate will be fresh so it should hold up
-Nick
Old Jan 9, 2002 | 07:57 AM
Nickerz's Avatar
Does this sound like a good grocery list of what im gonna need?
-ZZ4 Crate
-750cfm carb
-spark plug wires
-pulleys
-shorty headers
-oil filter adapter
-fuel pump
???external accessories.
So what all would you guys recommend for this swap. My fund limi on the swap is 4500, so...
zz4 $3,499.00
that leaves 1000 for accessories, can it happen?
What about the Speed-O-Motive 383? It looks as though I could get about 50 extra horsepower for the same amount of money!
-Nick
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
