305 to 350 accessory brackets
Old Oct 2, 2019 | 10:12 AM
Mhritz86's Avatar
So I'm in the process of my swap and I've decided to clean the bay up as well. So I know the factory 305 accessory brackets will bolt to the motor, but they look fugly. So I'm wondering what you guys have done for mounting your accessories.
I'm only losing my smog pump. If there isn't alot of options, can I just cut that section off the AC bracket and clean/paint the factory one to make it slightly better? I'd like to keep wiring/hose routing similar to factory so pump and alt in factory locations would be awesome, but I'm open to suggestions.
Thanks.
Old Oct 16, 2019 | 07:55 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
Re: 305 to 350 accessory brackets
there are aftermarket serpentine systems you can buy but they cost a mint. the factory system works great. clean and paint it and throw it back on. if its a show car then spend the money on the aftermarket but it its a real car there is no reason to drop 2k on it.
eddie jr
Jul 12, 2016 01:56 PM
atopjian
Jul 29, 2004 04:33 PM
chio987
Apr 24, 2004 10:59 PM
fazool
Aug 6, 2002 10:24 PM
JunkHead84
Jul 27, 2000 11:10 AM
