front wheel drive 3800 to f body camaro
Hi all. New to this board. I am working on a friend's 1997 3800 f body that has a blown engine. can a 3800 from a Buick replace it? I have read that there may be engine mount issues.I also want to know if the computer and wiring harness from the Camaro will work. This car is just a driver, no hot rodding. She doesn't have much of a budget so trying to cut costs as much as possible and I can get the Buick engine cheep. Thanks all.
Re: front wheel drive 3800 to f body camaro
The Thirdgen in www.thirdgen.org refers to the third generation Camaro/Firebird, aka 1982-1992. Maybe try camaroz28.com or ls1tech.com
Here, I'll help you out..
https://camaroforums.com/forum/93-02...nt-info-57568/
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Did see a '95 FWD supercharged 3800 installed into a '65 Chevy II once
-could be done into a 3G if someone really wanted to...
-could be done into a 3G if someone really wanted to... Thread
cicero819
16
Mar 4, 2017 09:15 PM
