Surface Rust inside Cyl.
Old Jan 14, 2002 | 11:02 AM
kabar14342's Avatar
i got this block after it had been rebuild and sitting for a year in a shed, its a 350 block that right before it was in storage was complete bored honed and rebuilt, because it was sittting for a while it had condensation inside the block which caused, oxidation, or surface rust nothing that cant be rubbed out with emery cloth or sending it out for a hone, i dont want to have to pull the pistons out unless i have too, and if i yank then out im going to rebuild any suggestions on what i can do with this
matt
Old Jan 14, 2002 | 02:45 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Rotate the engine around for each piston till they are at the bottom of the bores and then use scotch brite and penetrating oil to clean the rust off. This is not at all desirable because you may end up with crap in your engine and that sucks.
The best thing to do is hone it, why not do it right while it's mostly apart anyway? That's what I'd do.
Old Jan 15, 2002 | 08:54 PM
83 MidniteZ's Avatar
I definitely second Tom84L69's opinion...
pull it out and do it right. "A stitch in time saves nine" I had to find that out the hard way. Dropped my engine in two weeks ago, and hadn't double checked everything. Had to pull it all apart, strip it down turn the crank again..and start all over. Just do it right the first time.
Old Jan 15, 2002 | 09:00 PM
kabar14342's Avatar
yea. im def, going to do that, ive decided to buy a steel crank, new rods, forged pistons, new bearings, the whole nine yards, then when im done im going to send the heads out to be reworked, any suggestions on parts for the lower end???
matt
Fireslash
Apr 11, 2016 06:43 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Giocio
Oct 1, 2015 12:20 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
