Trying for 9s possibly 8s in the 1/8th
Old Sep 27, 2020 | 09:32 PM
9sinthe86TA's Avatar
Car: 1986 Pontiac Trans Am WS6
Engine: 383 Stroker
Transmission: TCI 725hp built 700R4
Axle/Gears: 94 Camaro 10 bolt. Posi 3.23
The current stock engine in my Trans Am is soooo slow. I purchased a 350 010 block this summer and plan to build it this winter. My overall plan is to go from running 10.25 to low 9s possibly 8s if possible. I don't want to overhaul the stock 700R4, I don't want to put a ton of money into the rear end. What power limits should I go to without burning stuff up? I was maybe shooting for 350 hp with heads, cam, intake, headers and a carb. Maybe more with nitrous. Does anyone know what I should do to achieve this goal?
Old Sep 27, 2020 | 10:07 PM
NoEmissions84TA's Avatar
Re: Trying for 9s possibly 8s in the 1/8th
Yes, buy this: https://www.thirdgen.org/forums/memb...-modified.html
Old Sep 27, 2020 | 10:14 PM
Engine: 383 Stroker
Trust me, if I had 20 grand laying around I would in a instant.😂
Old Sep 28, 2020 | 12:30 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
9 sec 1/8th mile is like a 14 sec 1/4mi car. 350 hp isn't needed depending on weight and gear. 300 is closer. Small roller cam, GOOD exhaust, even stock heads will get you there. Starting from scratch with just a block (a flat tappet, ancient block, even worse.) is a long up hill battle. A good vortec or a warmed up L98 can get your goal. I wouldn't recommend going to a carb but to each there own. Costs money to go faster, halfa$$ it and you get fulla$$ed results.
If it were that early 700r4 wouldn't be happy. I'm not super knowledgeable on upgrading automatics but even your goal might at least need a shift kit or shift point change.
Old Sep 28, 2020 | 12:55 PM
Engine: 383 Stroker
The shift point change is the first thing I was going to do. My Dad gave me a pair of otc heads for my birthday so I was planning to use those. That's why I'm not going with a vortec or the original TPI. I just want some more power. I'm getting sick of people calling my car slow 😂. And knowing this I'll just settle for 300 maybe a shot of nitrous for sh#ts and gigs.
transamaster
Nov 8, 2016 05:37 PM
GIJason91
Apr 10, 2008 05:44 PM
83' maro
Sep 7, 2007 10:26 PM
Synful
Jan 21, 2007 02:22 AM
19doug90
Sep 9, 2003 02:50 PM
