Trubo trans Am
Old Dec 21, 2023 | 01:16 PM
w41duvernay's Avatar
Car: 1986 Pontiac Firebird s/e
Engine: 305 Chevy
Axle/Gears: 2.77 for now
Trubo trans Am
Sirs, on Turbo Trans Am can 301 be swapped out with a Pontiac 350/326 instead and keep rest of OEM turbo equipment?
Old Dec 21, 2023 | 01:33 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Trubo trans Am
You'd have to check with late Second-gen guys is my guess. I'm not sure how many third gen guys will know. I'm being speculative but the short deck nature of the 301 might change geometry making it difficult or impossible to swap in the tall deck 326/350. I would think if it were feasible or easy more, people would have done it already. At the very least, used the turbo system on a swap into any other pontiac chassis.
Old Dec 22, 2023 | 08:25 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Trubo trans Am
No it can not. The Pontiac 301 and 265 are short deck V8 engines. The turbo intake manifold won't fit a normal Pontiac V8 engine.
This guy at TTA Performance can tell you anything you need to know about the 80/81 Pontiac 301 Turbo.
https://www.youtube.com/@ttaperformance1046
https://ttaperformance.com/
Old Dec 28, 2023 | 05:03 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Trubo trans Am
It could work with a fabricated adapter, typical 4bbl intake....or possibly by stacking intake gaskets, but it's definitely not a "bolt-on" for the reasons that Airwolfe said.
I think one of the problems with the 301 Turbo, is the "turbo equipment". It's not great. IDK how many hp you can suck through that carb base, or how much you can push through that little charge elbow, but I'd guess not much. There is no intercooler and the controls (non Computer carb, minimal ignition control in '80?) weren't good. I think it would be just as easy to build a system from scratch that is way more efficient, powerful and usable...and you could do that on any Pontiac engine.
R3500
Sep 11, 2008 11:59 PM
MattW
Sep 5, 2006 12:16 PM
tta1415
Jul 9, 2001 10:14 PM
