LS Swap With BMR Tubular K-Member Intake Manifold Clearance
Old Jan 18, 2025 | 12:24 AM
DeltaPi's Avatar
Car: 1989 Firebird Coupe (LS Swapped)
Engine: 5.3L L33 LS (2006)
Transmission: TR6060 M10
Hello, been working on getting a 5.3 ls engine (L33) into my 1989 Firebird, and have been trying to research what intake manifold I should use since I have been told the truck intake manifold is too tall and hits the hood. The only info I have seen is that the ls1/ls6/ls2 intake will work with the swap, but I am going to be using a BMR K-Member instead of the stock one so I wanted to see if there was anyone with the same k member that would know the clearance the engine has when its installed, so I know which manifolds will work and which won't.
Thanks for the help,
DeltaPi
Old Jan 18, 2025 | 12:35 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LS Swap With BMR Tubular K-Member Intake Manifold Clearance
BMR sits very tall in my car. Not a prayer with truck intake.
Old Jan 19, 2025 | 01:48 PM
DeltaPi's Avatar
Thanks, do you know the clearance measurement in your car from the engine to the hood or at least the height of the intake you are currently using?
Old Jan 22, 2025 | 10:51 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
DeltaPi
I've got a BMR k member in my car with an iron block 6.0L the k member has integrated motor mounts. I've got a BTR Trinity intake manifold with 1/2" spacers and it clears just fine with about 1.75" of clearance. I've got hood vents on my car so I can just look right in there and see everything.
I would think a BTR equalizer intake would fit no problem, an LS1/6 should also be good
Old Feb 22, 2025 | 08:26 PM
DeltaPi's Avatar
Awesome, thank you for the help.
Just about ready to get the new k member in so quite excited.
Thanks,
DeltaPi
Old Mar 16, 2025 | 01:54 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
right on the website:- Underslung plenum design for maximum hood clearance
-102mm profiled throttle bore
- 1 MAP sensor location in rear with 2 additional optional locations
- Additional user defined LS3 and LS1/LS2/LS6 MAP sensor bores
- ISO9001:2015 certified machining
- 2-piece design for easy porting access
- Lightweight CAD-generated design
- Profiled port openings for optimum out of the box performance
- All threads are roll form aircraft standard DSDV
- Clears F-Body cowls
- Clears C5 cowls with minimal massaging to intake
- Does NOT work with truck accessories
Old Mar 16, 2025 | 02:14 PM
DeltaPi's Avatar
Thanks for the help guys, I'll be on the lookout for a ls1 or ls6 since its in my price range. If I cant go with that I was thinking of trying to make a custom itb setup from some old smaller throttle bodies.
iroc-z_23
Nov 5, 2015 03:55 PM
calgutie
Carburetors
Nov 9, 2012 02:06 PM
trans slam
Fabrication
16
Mar 8, 2010 11:52 PM
jest629
Oct 14, 2008 01:35 PM
