LT1 into LO3 fuel pump ??
Old Feb 5, 2002 | 04:12 PM
90RSErik's Avatar
Been away from the board since i put the car away in August, but I have a question about my upcoming LT1 swap. I remember reading a while ago the pump flow numbers on my LO3 fuel pump compared to the pump flow numbers for an LT1. I can't remember the exact figures, but if memory serves, the LO3 pump isn't gonna cut it. Where can I get an adequate fuel pump that will fit in my tank? I guess what I really want to know is if I get the fuel pump from the donor car will it fit and work for me?
Thanks...any input is appreciated.
Old Feb 5, 2002 | 04:50 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
The pump from the donor car will work for this. If its a ta or camaro those pumps are supposed to be good up to about 400 flywheel hp.
If you get the sending unit and fuel lines also you will be ahead of the game(because you wont have to fab custom ones)
If you want to go with an aftermarket You could go with a Walbaro 255 . Thats what I have it will support 550hp and costs about 140 dollars through jegs and summit. It replaces the stock pump in the tank.
Hope this helps.
Kory
Old Feb 6, 2002 | 10:00 AM
90RSErik's Avatar
Thanks for the help Kory, that pretty much answers my questions, but I was hoping to get a few opinions rather than just one.
Old Feb 6, 2002 | 11:38 AM
jdrobley's Avatar
if you'r looking to replace it, go with the walbro.
check out this sight: http://www.autoperformanceengineering.com/
they have the 255 L/hour high pressure pumps for $108
Old Feb 7, 2002 | 12:52 PM
mat89RS's Avatar
you can purchase a regular TPI fuel pump for 69$ and it works well
Old Feb 7, 2002 | 02:39 PM
90RSErik's Avatar
is the TPI fuel pump different than the LT1 pump??
Old Feb 7, 2002 | 03:42 PM
jdrobley's Avatar
<qoute><b>is the TPI fuel pump different than the LT1 pump??</b></quote>
mat can correct me if i'm wrong but the TPI pump is just the name brand pump. (the company is called TPI). any electric pump will make your LT1 run, the problem is that it needs to create enough pressure to run right and generate enough power. the reason i suggested the walbro is that it has a good reputation on the board and if you order the holley one from summit, it will have a stamp 'made by walbro'. the pump matt suggested is definatly cheaper, though i don't know the quality. i have read too many posts about how someone put in a cheap pump and ended up changing it again after a couple of months. check with others to wee the quality of the TPI pump and make your own decission.
Old Feb 7, 2002 | 05:58 PM
90RSErik's Avatar
Thanks for clearing that up. Now that I think about it, I have heard of the company TPI. I just misunderstood and thought he was talking about the fuel pump from a camaro w/ TPI engine. I think my L03 has an electric fuel pump (correct me if i'm wrong) but it's not adequate to feed the LT1.
Thanks again! keep the posts coming
Old Feb 7, 2002 | 10:30 PM
Car: 88 Iroc
Transmission: t 56
a stock lt1 f-body pump or a walbro would be your best choice.
I don't know if you have ever removed a tank before. Its not fun. I am of the opinion that one is enough. I got a walbro because I didn't want to do it again any time soon.
I would buy a good pump the first time, double check all connections, and forget about it.
but that me.
Kory
Old Feb 8, 2002 | 01:00 PM
mat89RS's Avatar
what I meant is a Tuned Port injection , a TPI pump would work well because that's what I'm using ! it can supply up to 62 psi witch is fine to fuel up a 450 hp engine. Just go to any parts store and ask for a 1992 camaro TPI fuel pump
Old Feb 8, 2002 | 01:02 PM
mat89RS's Avatar
Your TBI fuel pump will not do any good for you ... and "no" TPI fuel pumps are not cheap !! it will last a long while .
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
