Part number for 1LE A/C delete pulley
Car: 1985 Camaro Z28
Engine: Caprice LT1
I need a party number for a 1LE A/C delete pulley for an LT1, I went to the local gm dealership and he couldn't find one on his computer. Any help is appreciated.
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I moved by alternator over to that side. I just made an extension bracket cause of the difference in the mounting bolts from a/c to alt. All I did was take a piece of 1/8 flat steel from some old bracket from who knows what, and made a 2" x 4" rectangel with two holes in in. A couple of rod ends connected works good also, then you can adjust the tension.
Then, cut your old belt, have someone pull the tensioner all the way back and cut the belt to fit. Then just take it to the auto store and have them size in up. I bought the two closest and returned the lesser of the two.
I got a a pic of the bracket if you want.
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
This is the # on my AC Delete pulley.10055890
Don't know if it'll fit on an LT1,but fits on 89-92 Serpentine setup for 305/350.
Hope this helps.
-Rich-
Hope this helps.
-Rich-
1992 Trans Am
May 10, 2023 07:19 PM
IrocZ'85
Aug 17, 2015 06:24 PM
TA8487
Aug 16, 2015 12:21 PM
