Used block from builder...or brand new GM block with boring?
Old Feb 19, 2002 | 09:27 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Brand new GM 350 1 piece rear main seal from Scoggin Dickey is $600. I will be building a 383...so I will need cylinders bored...and have the block clearanced for the crank. A local engine builder gave me this quote:
"The block would cost $650.00. It would be vatted and magnafluxed,bored and honed w/torque plates and clearanced for the stroker crank. If the block needed to be line bored that would be an additional 175.00. When we build a short block it comes painted with hi temp paint. As far as a warranty, most of the manufacturers we use have a warranty against defective workmanship. That is the only warranty that is applied. Hope this helps."
What do you think? I would think the block from the builder would be a used block....but im guessing it would be checked completely, so it shouldnt give me problems. What do you think?
Old Feb 19, 2002 | 09:44 PM
87RS402's Avatar
I personally prefer a good used block that has been freshly machined. New blocks haven't had any stress relieving done and some clearances will change with the first few heating/cooling cycles. A used block has already had the stress relieving done through normal use. (driving/parking = heating/cooling)
Old Feb 19, 2002 | 10:25 PM
Guest
Guest
Posts: n/a
You dont need the cylinders bored to make a 383, it will just be a 377 instead. I wouldnt do the .030 over on a new block just to pick up 6CI.
Jake_92RS
Jan 28, 2020 10:37 PM
C409
Jan 21, 2016 08:29 PM
Reddeath210
Oct 6, 2015 08:20 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
