maf vs. speed density
Old Mar 3, 2002 | 03:15 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
ok, my current 305 tpi uses the speed density sys.
if i swap in a complete setup from a bone yard, do i have to stay with speed density, or can i use a mass air flow system, and if so, what changes need to be made
Old Mar 4, 2002 | 11:24 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
what do you mean by "complete setup"
Old Mar 5, 2002 | 03:01 AM
Jza's Avatar
Jza
Double post. This new server is acting funky.
Old Mar 5, 2002 | 03:02 AM
Jza's Avatar
Jza
If you just swap the hard pieces (ei the block, heads, intake, etc) and don't touch the wiring, you won't have to switch to MAF.
Are you saying you want to switch to MAF? I mean, if you want to, then you'd have to switch out the wiring and computer as well, and I believe that means seperating the SD wiring from your body wiring in order to make the switch.
If I was in your position, I'd just keep what I have and change the block, cam, injectors, and knock sensor and call it done.
BumpaD82
Feb 26, 2016 02:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
