Where to get 383 ???
Old Mar 27, 2002 | 05:38 PM
Pete 85 Z's Avatar
For all you guys running 383's.Where did you get yours.I'm interested in the choices,and would you recommend the place.
Old Mar 27, 2002 | 07:01 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Get the GM 383 crate motor, it has a 4.0" bore and a 3.8" stroke, it makes a lot of torque.
Old Mar 28, 2002 | 09:11 PM
jamesbern's Avatar
Build your own if you can. G.M.'s is a good choice is you need to buy one complete.
Old Mar 28, 2002 | 11:00 PM
Pete 85 Z's Avatar
My friend says his dad would help build the motor,but I don't want to impose. I wanted to keep the budget to $3000.00,but now have decided on $4000.00 if it's a must.I also need to do trans, which I figured at 500.00 parts only,and pray the original diff will hold up a couple months for funds replenisment..
How much is the GM motor,and which one,I only saw a truck 383.
Old Mar 28, 2002 | 11:57 PM
Manny's Avatar
check this place out...........great stroker kits if you build your own.
www.enginekits.com
Old Mar 29, 2002 | 02:35 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
GM Part #12497317
Category Engine Assembly
Description ENGINE
Pack Qty 1
GM List GM Wholesale Our Price Core Charge
$5,150.00 $4,377.50 $3,605.00 $0.00
This is the HT 383 chevy crate motor, prices are from gmpartsdirect.com
Old Mar 31, 2002 | 12:02 AM
BLWR PWR's Avatar
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
Here is a link to some good info on the HT383 http://www.chevyhiperformance.com/in...rticleid=57841 .It looks like it rocks!
Old Mar 31, 2002 | 08:42 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I got my short block 383 from http://www.speedomotive.com/ , I also haven'y had any trouble with it. My only complaint was the wait.
Old Mar 31, 2002 | 10:51 AM
Pete 85 Z's Avatar
I was thinking about buying from them...Do you have emissions testing where you live,and if so,did it pass?
Old Mar 31, 2002 | 11:10 AM
1stgenracer's Avatar
get one from www.beckracingengines.com
they can make it emissions legal for u
Old Mar 31, 2002 | 07:37 PM
MorgRS's Avatar
The only thing I do not like about the GM motors are they are not balanced. Here are a couple places that seem to have some good packages:
http://www.built4speed.com/
http://www.diabolicalperformance.com/index.html
Good luck.
Old Mar 31, 2002 | 08:37 PM
Engine: 4.0L
No I do not have emissions testing. I doubt I'd pass either, I'm far from stock and have no emissions left on the car. None.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
