Help!!!!
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Help!!!!
Brian picked up my IROC last night and drove to Leicester no problems. Today on his home leg the car started to overheat and now there is a knocking noise Sounds to me like it could be head gasket???
Anyway AA are there and I was wondering if there was anywhere in Plymouth Devon, that could service/ sort the car out? Please let me know any details you guys may have.
Cheers,
Felix
Cheers,
Felix
Car: 2009 Volvo V50 R Design
Engine: 2.0 turbo diesel
Transmission: 6 speed auto
Axle/Gears: yes, both
Dunno if you saw my post on the AACI site, perhaps the ignition timing has slipped?
more likely than a head gasket, the engine is waaay too new, and they aren't prone to it without turbo / blower / nitrus..
seems a LOT more likely that a blown head gasket, its just not something that happens on 8000 mile GM crate engines..
Overheating with corresponding knock could be an indication that the oil was cooked and thinned to the point of having inadequate viscosity. Those knocking sounds might have been bearings.
Once the engine has cooled, restart the car briefly and see of the noise is present. Monitor oil pressure as well. If the noise is present when cold, mechanical damage mat have occurred. If the noise is not apparent, change the oil/filter immediately and avoid 5W-anything. Obviously, the overheating situation will have to be addressed.
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks for the advice Vader, the whole thing is such a shame. By the sounds of things, the damage is pretty serious.
I've posted asking for anyone with a 305 or 350 for sale to let me know as it could be an option for Brian in the interim?
Thanks,
Felix
Thanks,
Felix
Car: 1988 IROC Vert
Engine: 355 ZZ4
Cheers Phil. Taken your advice on Goodwrench engines too. ZZ4 is looking v. expensive with fitting!!
to be honest, you can go faster with a goodwrench, a set of used vortec heads, and some aftermarket goodies..
goodwrench is less than 100BHP down on the ZZ4 before you mod it, but its £3000 cheaper...
hmmmm. keepin fingers crossed dude..
surely the engine cant be a total loss??
Car: 1988 IROC Vert
Engine: 355 ZZ4
Cheers, maybe not. Hopefully the block will be ok and the heads could be reskimmed?
Hey Phil, want some hood struts? Going v.cheap
funnily enough, i have got a good pair on mine
Car: 91 camaro rs
How cheap?
Andy.
Car: 1988 IROC Vert
Engine: 355 ZZ4
Sory guys, private joke.
I put some new ones on mine about 5 years ago and they weren't working after 8 months
In the land of the struts- the broomstick man is King
ahh, see these are superior struts, mine have been on since June 03, and arestill 100% - you can lift the bonnet with your little finger!
Car: 91 camaro rs
I don't know! ZZ42 and Phil leading us up the garden path! Any sign of free (or cheap) parts and it's like vultures around a rhino carcass! Private joke indeed
Andy.
Andy.
you haven't seen a vulture untill you've seen me on form!
GWAAAAAAAAAAAAAAAAAAAAAK!
on a side note, any idea how to wire a 4th gen auto dimming mirror into a thirdgen?
