European Region For all of our Third Gen brothers and sisters across the pond!
wheels????
Old Aug 7, 2006 | 04:25 PM
joefish's Avatar
Car: camaro '83
Engine: 5.0 v8
Transmission: th350
Axle/Gears: not sure!!
wheels????
Hi can anyone help???/
Do corvette wheels go on a 83 camaro? if so do they go straight on? And what about wheel nuts???
Old Aug 8, 2006 | 02:43 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
I would ask that in one of the sections above, someone will definately have tried it.
Old Aug 8, 2006 | 05:36 AM
joefish's Avatar
Car: camaro '83
Engine: 5.0 v8
Transmission: th350
Hi Did that, no real info!!!!
Old Aug 9, 2006 | 02:59 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
HeHe,
Where did you look, Its one of the most talked about swaps for wheels. They will fit on, but you will need 2" adapters to make them work. Check out Skulte Performance Designs - Skulte Performance Designs. I was gonna go this route but am now going to get something else. If you can score some wheels cheap in the UK, then I'd say go for it.
Old Dec 27, 2006 | 07:46 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Corvette rims have the same bolt patterna s the camaro rims and most GM trucks as well. Should use corvette nuts and will screw in. Whether or not a rim will fit will depend on the backspacing to make sure the wheel/tire does not rub. You can get away with a 5.5 to 6" bakcspacing.
Thanks...........Bill............born in the UK.............living in Canada.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
