throwing out the cat
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I'm gonna try to take off my cat (its clogged) tomorrow and either replace it with a straight pipe, or hollow out the cat and put a pipe through it. Is it really worth the hassle to hollow it out and put it back on with the pipe going through just to avoid fines? I don't think I've ever heard anyone actually get fined for not having a cat, atleast not here in Miami.
If it is worth the effort, what is the best way to hollow it out?
Breaking the inside with a screwdriver and a hammer is what I've been told, but is it really that easy?
Car: 99 Formula
Axle/Gears: 342
What are emission like where you live?? Sounds like they're not strict, if that's the case I would just put a straight pipe in its place. To hollow it out everyone just says what you said.
Former Sponsor
Car: 1992 Camaro RS
There are no emissions testing here in Miami, atleast not right now. There used to be about 3 years ago though. I just don't want to get stuck with a $2500 fine for removing the cat. By the way, what should i do with the air pipe that would otherwise go to the cat? I am gonna go see if I can just take the entire pipe out of the car. I could always just cut it off and leave it there disconnected but that would just be a hackjob.
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Some states have visual inspections only. If that is the case there, then you would fail. You may want check on that before putting in a straight pipe.
ok heres what you do...grab ahold of the pipe and twist till it breaks...it is held in behind the pass side head by a bolt which i have tried to get many times but cant so i just broke it
Former Sponsor
Car: 1992 Camaro RS
We don't even have visual inspection here. The only problem I can think of is getting pulled over for something and having the cop check to see if there is a cat. Why would he do that? Some cops are just a$$es, and try to find as many things as they can to give out tickets to people they don't like.
LT1Formula
Oct 8, 2015 08:34 PM
