wiil v6 exhaust bolt up to v8?
Old Apr 27, 2002 | 07:53 PM
forbius's Avatar
i have an 87 with a 350 that needs exhaust... if i buy a v6 cat back, will it bolt up into the car and fit correctly to the cat flange?
ANY HELP WILL BE MUCH APPRECIATED!
Old Apr 27, 2002 | 10:46 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Still tring to figure out why you would want a V6 exhaust. I would think it would be to small. But other than the size of the pipe, I would think it could work. Look for the sizes on the V8 cat and the V6 cat. If it is the same then it should bolt right in.
Old Apr 27, 2002 | 11:11 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
You could always have a shop throw a glasspak on there or rig up some custom exhaust... and jc whitney has a 150$ or so catback for ya... if u wanna spring for a better setup, you could spend the 200$ on hooker catback...
Old Apr 28, 2002 | 08:16 AM
forbius's Avatar
i havve the chance to buy a $300 parts car that was a v6 but has a new aftermarket exhaust, iroc rims, and ok seats... and my car needs exhaust, so i was thinking instead of spending $700 for all those things if not more, buying this car and switching things out.
thanks for you help
Old Apr 30, 2002 | 05:16 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
what are you crazy yes it will fit with a little welding but
WYF
Old Apr 30, 2002 | 05:20 PM
jerflash's Avatar
sorry WTF
Old Apr 30, 2002 | 07:28 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Why not just spend the $300 on the parts car and $200 on a V8 cat-back, won't come to $700. Just an idea.
