Cat Temperatures...
Old May 13, 2002 | 10:52 PM
John'89L98's Avatar
Cat Temperatures...
I'm looking to get a straight answer on how to check a converter since the archives didn't seem to help. I believe the temperature before the cat should be warmer than after the cat, but I'm not certain. Either way, what is the temperature difference I should be looking for? Thanks. - John '89 L98
Old May 18, 2002 | 09:26 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i dont know about checking a cat by temperatures. i say just straight pipe it
Old May 19, 2002 | 05:49 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
The temp after the cat should be WARMER than before the cat.
I'd say at least a 25 degree F difference.
Old May 21, 2002 | 11:13 AM
John'89L98's Avatar
Hmm... So the cat is warmer after the cat than before? Are we sure about that? - John '89 L98
Old May 21, 2002 | 05:07 PM
breathment's Avatar
yes, since that is how the cat works. a chemical reaction occures which burns the excess polutants and stuff, and the byproduct is heat. which is why there is a heat shield around the cat..
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
