Could it be a blown Cat?
Old Jun 5, 2002 | 11:45 AM
PopaPork's Avatar
A few nights ago I was driving around and at a stop light I heard a noise from under the passenger side of the car. It sounded like the heat sheild on the Cat was lose and rattling around. Well today I got under the car and was looking aroundand the shield is on nice and tight. So I started to look at the hangers and welds to see if one was lose or something, all were good. So I took at a little tap on the cat to see if I could make the sound, and it did. It sounds like there is a tin can in the cat or something, like a baffle came out. Could this have happened? Or what else could it be? I gotta figure something out ASAP cuz it sounds like complete A$$. If it is a Blown Cat, any suggestions for a new one, besides a gutted? Thanks alot
Pork
Old Jun 5, 2002 | 11:52 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yup, it's the cat coming appart. Sounds like a good time to finish the job and hollow that bad motha out.
Old Jun 6, 2002 | 01:54 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
It sounds like the cat. Does the car heat up more than normal, or any loss in performance? Typically, if you beat on the cat with rubber mallot and hear rattling, then the cat is bad, which causes excessive engine heat, and poor performance. Unbolt it and check it out.
Replacement, no cat (like me), or hollowed cat (looks stock but isnt), or a Catco catalytic converter (for a performance stock replacement).
Old Jun 7, 2002 | 12:59 AM
HrdRockA4305's Avatar
Check the thread a couple ones up from this, similar discussion, I posted a pic you might wanna see too.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
