Chevy vortec egr
Old Jun 7, 2002 | 05:05 AM
Audiman's Avatar
Chevy vortec egr
Did you guys know if you run a 96 vortec pickup driver side exhaust manifold you can retain the egr with a chevy bowtie conversion vortec to TBI manifold, the only other piece you need is the crossover pipe. Better mpg's and cooler running at cruise are some pluses to this. EGR does not effect your emissions though.
Old Jun 10, 2002 | 08:15 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Chevy vortec egr
What do you mean by that?
Old Jun 10, 2002 | 01:31 PM
Audiman's Avatar
egr
where we live we dont have dyno testing, so when we rev an engine up at 2500 rpm with no load the egr does not open during the test, it does effect emissions under load as far as nox. The valve is designed to put exhaust gas in the chamber which deadens the air charge lowering nox. Unless you have dyno emission testing there may not be a need for the valve as far as testing.
Old Jun 10, 2002 | 05:18 PM
five7kid's Avatar
Thanks for the .
As a matter of fact, we do have the dyno emissions test here, and one poor guy out here is trying to figure out how to work around that with a 350HO swap and stumbled on this very issue (his bigger issue is he wants a shop to do the engine swap).
And, for what it's worth, California has the tech connect a vacuum pump to the EGR valve while at idle, to test the functionality of the valve. If it's working, the engine should stumble or die when the vacuum is applied.
So, be a little more specific in your statements, especially when they involve exceptions.
Old Jun 11, 2002 | 03:30 AM
Audiman's Avatar
It isnt all that hard to run an egr setup, as I understand it some models of chevy pickups came without it. so I wonder if there is a way to get a gm hood emissions sticker and just not run one? So for the illegal state of mind.
Old Oct 29, 2010 | 12:14 AM
shuggo517's Avatar
Does anyone have pics of the gm tbi vortec manifold with egr crossover pipe being used. On a 90-92 camaro tbi. I want to keep everything emmission legal. Please e-mail me at shugg@yahoo.com. Thanks Tony
Jorlain
Oct 8, 2015 01:57 AM
Kenwood
Sep 11, 2015 12:50 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
rjcme
Sep 5, 2015 01:23 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
