to O2 or not to O2 ??
Old Aug 14, 2002 | 10:32 AM
trickten's Avatar
If I lose the cat. can I just get O2 simulators, or will the computer screw up my fuel settings?
Alex
Old Aug 14, 2002 | 01:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The cat doesn't have anything to do with the O2 sensor. The sensor is located in the exhaust manifold/header collector, and the cat is down-stream of that.
Old Aug 14, 2002 | 07:52 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Hey. Well assuming you're talking about a thirdgen then removing the cat won't affect the O2 sensor. (As said before) But if you're talking about a newer car that does have another O2 sensor after the cat then you'll probably just set a code. Even then, from what I know, the second O2 sensor is just to monitor emissions and doesn't affect the fuel settings.
My 2 cents,
David
Old Aug 15, 2002 | 10:08 AM
trickten's Avatar
Thanks fellas. I just want to lose the cat and didn't know if doing so would throw a code. I appreciate it.
