Hows this exhaust system?
Old Aug 22, 2002 | 12:48 AM
Quik0781's Avatar
Will this exhaust system bolt right up with no trouble to my 91 RS Camaro 305 5spd?
slp headers 1 5/8
catco cat
hooker cat-back exhaust
Old Aug 22, 2002 | 04:02 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
It should assuming you have the right catco and hooker exhaust parts, it should be no problem. You may have to do some welding.
Old Aug 22, 2002 | 04:26 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It will as long as you order the parts so that they hook together. If the headers have a 3" y pipe, then get a 3" in/out cat. And if you want to save some money, order a cat with a 4 bolt flange to the I pipe, and you can order the $200 Hooker cat-back.
Old Aug 22, 2002 | 08:34 AM
MelloYello's Avatar
That system will work, but depending on emissions requirements, you may not pass emissions. I have a '90 TPI 350 and with optimum tuning and a catco cat I was only able to get my HCs down to 1.54. When I installed a Dynomax Superflo cat, my HCs went down to 0.28. I just had my cat flanged and an eliminator pipe made so that its not a restriction when I'm not doing emissions testing.
69 Six Pack
Oct 5, 2015 07:51 PM
backtothe80s
Sep 5, 2015 12:39 AM
TheExaminer
Aug 26, 2015 04:59 PM
makaveli09
Aug 12, 2015 09:07 PM
