Tick-tick-tick
Old Sep 15, 2002 | 08:26 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Tick-tick-tick
I made the mistake of using the gaskets that came with my Hedman headers, and i've got an exhaust leak.I've already replaced the collector gaskets with with ROL steal core ones,but i think it's leaking at the header itself.I've heard good things about the Felpro #1444 gaskets but wondered if they are compatible with my exhaust ports.Are they ok to use on 87'and up heads?(Mine are off a 94' 5.7 tpi truck) The reason i ask is the book listed different port sizes for gm heads and with the headers on,i can't measure mine.Thanks.
Old Sep 15, 2002 | 10:19 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If I recall you need the circle port, I forget though, so ask and someone might be able to help ya, or just call summit. I wouldn't use fel pro's on header gaskets, get the copper or aluminum ones.
Old Sep 15, 2002 | 10:29 PM
TBI305Camaro's Avatar
Yes definetly spend the extra cash on the copper or alluminum ones. I had planned on swapping heads along time ago so when I did the headers I just used the paper gaskets....some reason my hookers came with two sets..well lets say they are gone. Blew one day when I was driving it hard.
Old Sep 15, 2002 | 10:48 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I would reccomend Percy's dead soft aluminum gaskets. I haven't had any leaks (course the locking bolts help too). Definitely don't skimp out when it comes to header gaskets/bolts, it's worth the money.
Old Sep 18, 2002 | 03:24 PM
Marc 85Z28's Avatar
Compressed asbestos or graphite compound gaskets will leak. Copper gaskets will leak. Dead-soft aluminum will leak. Percy's probably will too - haven't tried them yet
The only thing that worked for me was Permatex Ultra Copper. Unbolt the headers, get a bunch on your finger and smear away. Sealed for LIFE! Gas, heat, high pressures, etc can't touch it. But be warned, when it comes time for removal you will need a pry bar.
Old Sep 18, 2002 | 05:34 PM
Car: 99 Formula
Axle/Gears: 342
I think I would take my chances with the aluminum or copper ones before I'd go that route.
Old Sep 18, 2002 | 11:31 PM
rezinn's Avatar
I'm using fel-pro gaskets, they've worked fine for years. Just make sure you get good bolts and you'll be okay if you torque them down enough. Only place I've had leaks is at the collector.
