Help with installing Y pipe?
Old Sep 26, 2002 | 09:12 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Ok, I got the SLP ypipe for my car, and I thought it came with the gaskets and everything you need but apparently not. What gaskets do I need? Just a 2 1/2(or was it 2?) inch exhaust collector gasket? What kind should I get, do they make these in those copper or aluminum ones? My plan is to soak the bolts with rust eater the day before.... keep shooting them with it on and off all day, then the next day have at it. Seems pretty straight forward, but my dad is sorta freakin me out talking about it being rusted on and stuff.....
Old Sep 26, 2002 | 11:46 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Yeah, unfortunately SLP does not include installation items with their headers...you have to buy their overpriced installation kit.
If you are just doing the Y-pipe, all you will need is two 2.5" collector donut gaskets.
If you are doing the headers too (which I am guessing you are, because otherwise why would you be worried about snapping collector bolts? just use new ones...), you will also need a set of header gaskets and make sure to use at least grade 8 bolts and coat them with anti-seize. I also found that the bolts with the recessed allen wrench heads work best so that you can get every bolt tight.
As far as the rusted bolts go, my dad was also getting me all worried about snapping bolts when I was about to install my SLP headers back in August. I sprayed all the bolts a few times with PB Blaster the day before my install and had no problem removing the 20 year old manifold bolts. Just make sure that you bend back the stupid metal tabs covering the first and last manifold bolts (maybe more...cant remember) so you will be able to get a socket on them.
Good luck!
Old Sep 28, 2002 | 04:20 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
And you have to use SLPs gaskets, if you use a simular one from felpro, you will have a leak.
Old Sep 28, 2002 | 05:35 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
My Edels came with 2.25" donut gaskets.
Old Sep 28, 2002 | 05:45 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
The hookers didn't need a gasket. They are a self sealing. Or atleast mine are.
Frozer!!!
Jan 19, 2024 04:55 PM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Sep 8, 2015 03:38 PM
transaero
Aug 31, 2015 01:14 AM
drathaar907
Aug 6, 2015 04:20 PM
