Bringin' the heat
Old Oct 7, 2002 | 08:26 AM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
Bringin' the heat
Hey all, I'm in the process of replacing my cracked y-pipe. I am also doing the clutch so while the tranny, bellhousing, and clutch & flywheel are out I have plenty of room to get at the manifold studs (which are snapped off). I have been soaking the studs from the top and plan on twisting them out (I have a good two inches to grab onto). I also have to disconnect the pipe from the cat. I figure a little bit of heat would help loosen things up at both these spots. My question is, what is the best way to deliver the heat to these two areas so I can get on with the resto? I'd prefer to not blow up my house, or me for that matter.
Kevin
Old Oct 8, 2002 | 08:22 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
The only idea I'm coming up with is a torch. Oxy-Acetylene if you have access to one, or even a propane torch can work if you're patient. I'd have a dry powder fire extinguisher on hand just in case. Be careful and Good Luck.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
