Cat-Back's
Old Sep 18, 2000 | 09:44 AM
Formula92's Avatar
Cat-Back's
Anyone out there install a Edlebrock cat-back exhaust? How does it sound at idle and when you step on it? Are you happy with the unit and did it all go together the way you wanted it to? I have the dual convertor from the factory. My son bought the Flowmaster set-up, the American Thunder unit and this one has dual 3" pipes out the back. Does the Edlebrock unit have 3" pieces out the back? The flowmaster sounds good at idle but i don't like it when you punch it. It has a crackle in it.
Thankx for your input.....
92 Formula,305HO,Factory Oil cooler,Hyper-Tech Chip,Hyper-Tech Coil kit,Dual-Core Split-Fire wire set,Hyper-Tech Airfoil,Accel Fuel pressure guage mounted on fuel rail,Crane Adj Fuel Pressure Reg,March Performance Pulley set,Four Wheel Disc Brakes,WS6 Package,Dual Convertor Exhaust,3.42 Gear/w POSI,5Speed Borg Warner Tranny,Center-Force2 Clutch Set-Up,K&N Filter.
chevyboy07 91
Aftermarket Product Review
Nov 14, 2001 07:46 AM
RyanSS
Nov 13, 2001 09:14 AM
Bimma86
Oct 27, 2001 07:16 PM
