Welding over jet-hot?
Old Sep 26, 2000 | 09:16 PM
86Trans Am's Avatar
Is it alright to weld over jet-hot? I'm ready to have my cat back put on and need to know how to go about welding the two piece slp y-pipe and then the y-pipe to the cat adapter.
Should i get the cat welded in also, and if so, are there any probems with changing it when the time comes. Basically i'm asking what should NOT be welded on the exhaust system.
thanks
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Sep 26, 2000 | 10:24 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
You should not weld over Jet-Hot. Wherever you need to make a weld you should sand the Jet-Hot off in that area. It should only be about 1/4" to 1/2" on each piece that need be sanded.
Also, I would not reccomend welding the cat in place. Because then if you ever do need to replace it later on you have to cut the old one off and weld the new one in. On my setup I put collector flanges on both sides of the cat, and on the y-pipe and intermediate pipe. That way I am also able to fabricate up a piece of straight pipe with flanges on it and just bolt it in and out for going to the track, but still run a cat the rest of the time.
Black 88 GTA L98
!Airbox, !IAT, !MAF, !TB, !Plenum, SLP 1 3/4" headers, Dynomax Hi-Flo cat & cat-back, Corvette Servo
14.389 @ 95.2 mph, 2.001 60' {Before headers, new times coming soon)
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
LC2 TECH
Oct 13, 2015 11:53 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
