For anyone who has installed Edelbrock TES headers
Old Nov 12, 2000 | 04:38 AM
1989CamaroRs's Avatar
Im going to put on my headers today and iwas just wondering a few things, were you able to put them in without having to lift the motor? is it a pain in the a$$? any tips?
Old Nov 12, 2000 | 08:57 AM
rusty Z's Avatar
I installed my headers last spring onto my LG4. A word of advice is to take your time. Use jackstands if you have them or ramps, with wheel chocks of course, otherwise you'll never get them on! You will have to pull the air cond assembly off to get to the bolts, fun fun! Also the brace connects the steering pump. I just kept all of my bolts in marked jars for reassembly.The driver's side is easier because there is less clutter. Remember to take out your spark plugs! The passenger side is a little more challenging with the starter and all. You will find that rocking the header a little will allow it to fall into place. Other than the tight fit I didn't need to pull the motor. Good luck!
Old Nov 12, 2000 | 11:56 AM
Blade's Avatar
You dont have to take you A/C assembly off and you wont have to take you plugs off. Mine slipped in very easily. I had to use a lot of pressure on the passanger side one but it was easy. YOu can get to the bolt no problem but on the passanger side you'll probably have to get em from underneath the car.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.dhs.org/Members/...dmondIndre.htm
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
Zeek1041
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 02:00 PM
drathaar907
Aug 6, 2015 04:20 PM
