Can I put a 5.7 Exhaust on my 305?
Old Dec 20, 2000 | 12:08 PM
Justin91RS305's Avatar
Will this work?
I would like to upgrade the exhaust on my 305TBI to the 5.7. Mainly, I only need the pipe from the converter to the muffler, but just curious if the bigger pipe will have any effect.
Thanks, and sorry for the stupid ?
Justin
91 RS w/305TBI
K&N's
Looking for a B4C that is CHEAP, and doens't have a LOT of miles!
Got one, Let me know
Old Dec 20, 2000 | 02:08 PM
Dan87IROC-Z's Avatar
The only effect it will have is that it will make your car faster and louder, although not by that much. It should just bolt right up without any additional modifacations.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
Old Dec 21, 2000 | 05:08 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep you definitely can do it. My dad put a y-pipe and cat-back exhaust from a stock IROC on his 92 RS TBI, and it gained 8 HP and 20 TQ at the rear wheels.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 21, 2000 | 10:33 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Are you only talking about the cat back? If you are, it won't bolt up. Even if it did, you wouldn't get much out of it because of the small y-pipe and cat. If you were planning to swap the entire exhaust including the manifolds(tbi manifolds won't work), then you would see a significant gain. My brother did exactly that on his 305TBI in combination with an open element air filter and gain about 1 second in the quarter.
Old Dec 22, 2000 | 01:01 AM
Kevin91Z's Avatar
No it wont bolt up. You will need to modify the y-pipe to bolt to the exhaust manifolds, like my dad and I did. (I forgot to mention that) Dont bother taking the exhaust manifolds off unless youre putting on headers. Its not worth swapping them.
Old Dec 22, 2000 | 10:49 PM
Car: '89 GTA
Engine: ZZ6TPI
I agree with not swapping manifolds. I did it only because I got them for free, but after a day and a half of fighting with it, I now wish I had done headers even though it would have costed more. Still was a significant gain though.
89 Transam GTA, a few bolt ons
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
jharrison5
Aug 19, 2015 05:53 PM
