Will I have any back pressure this way??
Old Dec 28, 2000 | 03:26 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
I want to run SLP 1-5/8" headers and the SLP 3" cat-back. Now i won't have any cat on there, prolly just a 3" test pipe. Will i have any back pressure or should i get a high flow cat or even a medium flow cat just to create some back pressure. You can see my list of mods in my sig. But by the time this is finished I will also have L31 Vortec heads on there too running about 9.5:1 compression. Any thoughts??
BTW: Yes, I willl also have a custonm prom
Thanks,
Lars
'92 RS 305 TBI
K&N Open Element
Ultimate TBI mod's (thanks Pablo)
Cam[.442"/.465"] x 218*/224* @ .050", 10:1 Hypereutectic Pistons
Performer Manifold
Shift Kit, Corvette servo,
and 2800 Stall Trans Specialties Converter,
Gutted Cat, IAT Resistor
MSD Blaster Coil, Accel Cap and Rotor
Old Dec 29, 2000 | 09:18 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Never ran into this on the "new electronic" cars. On the pre-computer cars I've had not enough back pressure can be a problem. On both cars the lack of sufficient back pressure made the car feel kind of limp and lifeless until the engine was wound up above 3500 rpm. Then you could feel the engine "wake up". Installation of slightly smaller tail pipes solved the problem and made the engine responsive at low rpms.
Z's r Best
Fronzizzle
Mar 18, 2019 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Kaweh
Aug 9, 2015 02:54 PM
