Ok finally got the longtubes and duals setup....
Sounds NICE!!! but (there is always a but) i have maybe 3 inches of ground clearance between the mufflers and road...not good. I had a fatass friend of mine with me and we scrapped creeping over railroad tracks
very very low
BTW i had no problems with clearance from the hedman headers. everything bolted up and everything very clean looking exhaust but ground clearance is horrible. Next check im gonna pick up a set of stock springs for the rear so maybe it will raise it at least and inch since the springs are stock.
very very low
its low but OMG it sounds like a freakin beast. I also have an equalizer pipe and turndowns that are turned to the side (for clearance purposes lol) it sounds real good
motor is running really wierd so i havent heard it at a true idle or anything yet. plus my motor is sputtering and spitting all kinds of bad stuff...idling at 2500rpm to.
Got the idle down. Turned my fuel pressure to 5psi and it helped ALOT and the car is running great now. Starts so easy to even in cold. The holley SA with the electric choke is just as driveable in the cold as the TBI.
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
