LONG TUBES ?? FIT PROBS?
Old Jan 4, 2001 | 11:01 PM
RARE-ROC-Z's Avatar
ok i see all these hopped up f-bodies out here with LT headers and it goes against everything i was told from an exhaust guy. THEY WONT FIT, THEY WILL DRAG, just flat out dont get them and i didnt want 1-5/8" headers so i skipped it b/c of money.. and now what all of a sudden they fit what the heck .. well i will have my engine out this spring and i will be repainting everything so i wont have to install around motor.. but i want someone with them to verify that a car that is lowered no more than 2" can have these ( i may not even lower ) but if i do. i would like to know i can still drive it safely. thanks for anyones help. and pictures from the side of your car underneath if poss. will help. and pics from top down showing how far they come out will also. thanks everyone.
1990 IROC-Z L98 350 TPI
AFPR 49PSI, GUTTED AIR BOXES, K&N, RAM AIR, PORTED PLENUM, B&M SHIFTER, 3.23 LIMITED SLIP, DUAL CATS, STOCK SUPER TURBO EXHAUST, COOPER COBRA XST's
MUSTANGS...ONLY 4 LUGS....HAHA THAT IS HILARIOUS.
Old Jan 5, 2001 | 03:40 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I am in the same boat as you. I keep hearing that people install long tubes and get away with it but then you call summit or jegs or a manufacturer and they say you need to modify the floor pans or that you wont be able to lower the car.
I have been strongly leaning twoards getting hedman's 1-5/8 long tubes and welding in an o2 sensor and then just putting on 3 in turndowns. I think this will be a killer setup but I still havent commited because no one has given me a for sure "they will fit" encouragement.
Oh well I guess thats what this board is for huh
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax exh, urethane motor+trans mounts,
SSM frame con, Bilsteins
very trick homemade ramair.
Old Jan 8, 2001 | 08:35 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
My car is lowered and I was wondering about the Hooker long tubes also. Does anyone know they will fit? Do they have an O2 bung and a y pipe or what?
Chris
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
Old Jan 8, 2001 | 02:33 PM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
My car is not lowered and I have the Hooker long tubes and they fit great. I seriously doubt that there would be a problem even if the car was lowered. I will try to take some ground level pics and post them.
They did not come with the O2 bung but I bought one and welded it into the collector.
[This message has been edited by Hurtin4Hp (edited January 08, 2001).]
Old Jan 9, 2001 | 09:42 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I have hedman full length headers with 1 5/8 primaries. They fit very well with no ground clearance problems but my car is not lowered. The key to not having ground clearance problems is making the y-pipe. I had one custom made my a local shop that turned out great, I lost maybe an inch of clearance compared to the stock exhaust. I didn't do anything to the floorpans either. I have some exhaust pics on my website but sometimes the link doesn't work, not sure why. If it doesn't work click it a few times and it may work or just email me and I'll send you some pictures.
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
87iroctheo
Dec 4, 2016 11:47 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
beast94
Aug 20, 2015 06:44 AM
