Is my Y-pipe Choking my power?
Old Jan 15, 2001 | 05:46 PM
Sals82Z28's Avatar
In my 82 is a 350 bored "060 with a Compucam 272/284 454/480, Crane Gold Roller Rockers, Edelbrock RPM manifold, Holley 650 duel feed, AFR 190 Heads, Hooker shortie headers, a TCI Saturday Night Special converter, 350 trans, 3.42 rear, custom y-pipe into a 3" Dynomax exhaust. The car sounds like it chokes up when I get on it. It doesn't even break traction, timing and fuel is right on. The Y-pipe is a duel 2 1/4 into one 2 1/2, where the cat should be,about twelve inches long then dumps into the exhaust. With this set-up should I get a more open y-pipe, poss 3", to flow the exhaust better? I should be pushing close to 380-400hp and the car feels as slow as my cavalier which is a whopping 2.0......or should I buy SLP 1 5/8 headers and y-pipe?
Old Jan 15, 2001 | 06:28 PM
CamaroMike's Avatar
Your running AFR's through a 2 1/2" y-pipe. Good Greif! Open that thing up. A 350 like that should really have dual 2 1/2" pipes dumping into a single 3.5" y-pipe. The best your gonna find though is a single 3 but do anything and that engine will wake up.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Jan 16, 2001 | 06:51 PM
Sals82Z28's Avatar
Thanks so mch for the advice, I'll definately get this done. Where can I get this done? Does Midas or Meineke do good work with this? And do they stock 3 1/2" pipe to do this? Thanks again.
Old Jan 16, 2001 | 08:16 PM
CamaroMike's Avatar
Just get a header and y-pipe combo from Jegs or Summit. I prefer SLP's 1 3/4 inch headers but they are really expensive. Edelbrock is not a good brand, believe me I have them. Hedman or Hooker makes a header and y-pipe setup. If you are rich go to www.mufflex.com and check that **** out. Whatever you do don't go to a muffler shop. They will crimp bend your exhaust and you want mandrel bent pipe so the diameter is not reduced. Good luck!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Sep 8, 2015 03:38 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Out-Cast
Aug 22, 2015 07:49 PM
