Loudnest?????
Old Nov 17, 2002 | 03:43 PM
86TransAMsbc305's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
Loudnest?????
I want some loud, powerful sounding exaust...If i took my cat off and put a single 80 series flowmaster muffler on, will this be loud???? And if i take the cat off will it affect the O2 sensor or the computer???
I have an 86 TA, 305-4barrel....stock manifolds.
Old Nov 17, 2002 | 03:48 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Yea, it should be pretty loud.
And no cat wont mess with the computer.
Old Nov 17, 2002 | 03:51 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It will help some, but that stock exhaust isn't goin to help the sound much, but it will bit a bit louder.
Old Nov 17, 2002 | 06:00 PM
TBI305Camaro's Avatar
thats wont be very loud...I had that setup on mine exactly for awhile. Then i switched to hooker shortie headers and it was pretty loud but didnt turn to many heads...now I turn heads from 1/2mile away
Old Nov 17, 2002 | 08:40 PM
Engine: LG4 305
So you're saying a single 80 series flowmaster muffler won't be loud??
Old Nov 17, 2002 | 09:11 PM
Car: 1988 IROC-Z
Engine: 427 SBC
I dunno, even though the exhaust is stock, a 80 series with a gutted cat should be kinda loud......
Old Nov 17, 2002 | 09:43 PM
Car: 99 Formula
Axle/Gears: 342
It won't turn heads, but it will sound a lot better.
Old Nov 18, 2002 | 08:11 AM
Brett Gutshall's Avatar
my car with some unknown 2.5 inch mandrel bent catback and 80 series sounds pretty good. Not "Loud" but turns heads and roars pretty good when you're on it. However, my buddy's TBI Iroc with the same setup (2.5 mandrel catback, 80 series, stock cat/manifolds) doesn't sound anything like mine. His is actually really quiet. So I guess a lot depends on the cam/cat setup. Also make sure you have at least a 2.5 inch intermediate pipe. I'm hoping to go to a 3 inch sometime soon, which should only make it better.
Old Nov 18, 2002 | 09:05 AM
1989camarorsrs's Avatar
Buy the 3 inch cat back from either flowmaster or hooker, and run a straigt pipe instead of cat if u want it realy loud. Just the muffler isnt enough, The other 3 inch piping realy helps the sound and performance.
Old Nov 18, 2002 | 11:04 AM
headers made a bigger sound difference (and power difference) than just a muffler i think.
Like I said I had that setup and it wasn't very loud...headers made a big difference tho.
Old Nov 18, 2002 | 11:21 AM
Knight350's Avatar
Yeah, you guys are right, It may sound a bit louder and better, but later on the 3 inch pipe and header will kick it up alot more... also the angle and cut of you tips will affect how loud it sounds from inside the vehicle.
Old Nov 18, 2002 | 05:12 PM
BillZ28's Avatar
Car: 84 Z28
I have the 80 series and no cat and it is pretty frickin loud. But I have heard other 3rd Gens with the same setup and they aren't as loud. Must have something to do with the L69 setup.
Old Nov 18, 2002 | 08:43 PM
80 Camaro 355's Avatar
Car: 1980 Camaro Berlinetta
Engine: soon to be 383
Transmission: TH-350
Axle/Gears: GM 10 bolt 8.5 3.23
My buddy Black85Camaro has an 80 Series Flowmaster w/o a cat and w/o tail pipes.And its louder than both of my 40 Series Flowmasters with an X-pipe and i have tail pipes also......
Old Nov 18, 2002 | 09:11 PM
Momar's Avatar
Its probably because of your 3" exhaust.
Ben
Old Nov 18, 2002 | 09:51 PM
Knight350's Avatar
If you get turn down tips and dump the exhaust closer to the muffler itself, the interior noise will increase.
Since you friend does not have any tail pipes, the exhaust resonates between the car and the ground as oppose to just flowing directly behind the car.
Old Nov 18, 2002 | 10:14 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
That's what I have......and a 3 inch exhuast cut out with an electronic McCord Power Plate II Talk about loud.....now this thing is loud! This dosen't turn heads.....this breaks necks....LOL...just depends how loud you want with out it sounding trashy.....this is all on a 5.7 L98 too...that makes a difference too.....
Old Nov 18, 2002 | 10:20 PM
Engine: LG4 305
What is an electronic McCord Power Plate II ?????
Old Nov 18, 2002 | 10:25 PM
Engine: 5.7
It goes at the end of an exhaust cut out. It's an electronic vavle that allows you to "tune" your cutout.....or some people say " a tuneable exhaust leak" LOL....it's electronic.....by the flip of a switch from inside your car.....you can tune the exhaust cut out to how loud you want it...here is the link if you wanna take a look at it.... http://www.mccordcg.com/mpp/pictures.htm
Old Nov 19, 2002 | 08:17 AM
with turndowns turned sideways on my dual setup and 2 chamber flows I get A LOT of interior noise.
I think having no tail pipes at all sounds really trashy and sounds alot like a dump truck. My setup sounds pretty nice on a 9.6:1 350. I like it alot.
Unless you have to have a muffler now to pass state inspection or something i wouldnt get a 2.5 inch flow...id just wait until you could afford a 3'' hooker catback or something.
Old Nov 19, 2002 | 09:30 PM
I used to have turn downs before the rear axle but it got really annoying and the fumes from the exhaust ran into the car.And I used to have 50 series Flowmasters (3 chambered) Those sounded great with the X-pipe. it sounded like the 4bbl was open crusing at 30mph! but that was also with turn downs before the axle.I kinda wish i would have kept the 50 series somtimes now!
