to the intellagent people of the message board
Old Feb 5, 2001 | 04:49 PM
85F-body's Avatar
do i need to recalibrate if i get new headers and also if i get new cylinder heads
Old Feb 5, 2001 | 06:03 PM
The ODB's Avatar
Definately need more information about your car to be specific.
On carbureted cars, when you make a significant decrease in backpressure it will lean out your mixture in most of your driving RPM range.
With fuel injection or computer controlled fuel delivery, you might as well flip a coin before you second guess your A/F mixture.
The most reasonable way to tune (assuming you don't have a wide-band O2 or lamda sensor) is to use an acellerometer like the vericom or g-tech. Do the test runs and play with the A/F mixture looking for highest trap speeds.
That way you know for sure what your car wants in the way of fuel.
Old Feb 5, 2001 | 06:38 PM
85F-body's Avatar
i have an 85 i roc z camaro 305 tpi v8 engin code f
Old Feb 5, 2001 | 06:39 PM
85F-body's Avatar
o ya and i do have an o2 sensor
Old Feb 5, 2001 | 06:56 PM
The ODB's Avatar
Ok then your system will pretty much adjust itself during normal driving and my only go a bit lean at full throttle, but that's usually a good thing for power.
At the very most you may try changing the fuel pressure while you're testing full throttle runs via track or acellerometer.
Chances are a fuel pressure change will be of no benefit. And definately do not switch to larger injectors on a 305.
good luck with that.
Old Feb 5, 2001 | 07:38 PM
The Rusty Trombone's Avatar
"to the intellagent people of the message board" -- what an odd statement. SPELL CHECK!
1987 Midnight Blue Camaro IROC-Z, 350 TPI out of an '88, Accel 8.8 wires, hypertech air foil, flowmaster american thunder 3" dual outlet cat-back... slipping tranny!! (T5 swap next spring!!)
http://banners.wunderground.com/bann...hackensack.gif
Old Feb 5, 2001 | 10:23 PM
85F-body's Avatar
i am not that much of a speller or a reader at that so i really don't care
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
6998poncho
Sep 25, 2015 02:56 PM
