Flowtech's 1.5inch Help Techs! in a rush!
Old Feb 6, 2001 | 03:57 PM
Steve89GTA's Avatar
Why 1.5 inch? Is this enough for a 305TPI with ported intake and cold air setup. My ultimate plan is to put on an ATI Supercharger (after a rebuild). Will these flowtech's bottleneck my performance on the exhaust side? if so...then I should go with 1 5/8?
Thanks for your help!
89 GTA G92
305 TPI
WC 5spd w/3.45 rear
Accel Cap & 8mm Taylor's
Crane Ignition
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch
Hypertech Thermomaster Chip
Steel Rad
Cat back 3" Exhaust
HiGh FlOw Dynomax Cat
Old Feb 6, 2001 | 04:41 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
1-1/2" are for stock-mild 305.
1-5/8" are for mild-serious 305 or stock-mild 350.
1-3/4 are for very wild 305 or serious 350+.
Go with 1-5/8 since you plan on an ATI.
George P. Lara
1984 "L69" A4
1994 LT1 M6
Member:
SCCA, SCFB, SC3GFB
Old Feb 6, 2001 | 08:57 PM
Jester's Avatar
1 1/2" -engines under 300hp (read: most all of them if you're honest)
1 5/8" -engines 300-350hp
1 3/4" -over that
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Pac J
May 17, 2020 10:44 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
