True Duals?
Old Mar 3, 2001 | 10:55 AM
Teal25thL98's Avatar
True Duals?
I have a stock L98 92 Z28, was wondering if putting true duals would hurt my engine in any way? Also I planned on two 2" pipes from each cat to the tail. Any suggestions are greatly appreciated
Old Mar 3, 2001 | 11:01 AM
vortech305's Avatar
True duals isnt possible unless your just drag racing. Also depending on what true dual your talking about. Straight pipe from header to exhaust tip would hurt your ground clearance. True dual from factory setting(its possible ive seen it) will someone help but cost money. My opinion not worth it. If u have a stock motor stay with a Single 3 inch free flowing exaust system.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
