Exhaust leak?
Old Mar 4, 2001 | 06:08 PM
84TransAm's Avatar
Exhaust leak?
When i turned off my Trans Am the other day, i noticed there was a blackish smoke spitting up from the joining of the exhaust manifolds to the heads. This occured at both heads at the same time. I assumed the catalytic converter was clogged, went to investigate, took it off and SUPRISE! no insides to the cat (sorta nice to find out, but a biotch to get to).
So my question is, do i need new exhaust manifold gaskets, or is it valve cover gaskets? I just put in new Felpro vavle cover gaskets not more than a month ago on both heads. Thanks for any help.
(PS stock exhaust system so far.)
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
NOW FEATURING: Holley 600 cfm & vacuum advance
Old Mar 4, 2001 | 07:59 PM
84TransAm's Avatar
btt
Old Mar 4, 2001 | 11:41 PM
The ODB's Avatar
valve cover gaskets
Old Mar 5, 2001 | 08:49 AM
84TransAm's Avatar
SON OF A....
Old Mar 5, 2001 | 10:53 AM
JETHROIROC's Avatar
Make sure you have good exhaust flow first, but I'd say ODB is right. It would be unlikely that both manifolds leak at the same time. Did you use a torque wrench on the valve cover bolts when you reinstalled them? I used Fel-Pro too, but torqued the covers really carefully and I've never had a leak. May want to make sure your PCV system is operational too. Good luck with that, man .
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
ericjon262
Sep 11, 2015 06:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
