I want to get rid of the Edelbock headers I have.The AIR tubes are in the way and I want to step up to longtube headers.What is the
collector size?Also what is the primary size,
1/2,5/8,or 3/4?
If its 5/8 primary,they should still flow better than the Edelbrock 5/8 shorties.
Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
TCI shift kit
Vette servo
B&M 3-4 upshift kit
TCI Trans Rebuild
2800 stall 9.5" TC
Nitto Drag radials
FUTURE MODS:
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
1/2,5/8,or 3/4?
Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
W/P Torquer heads
Edelbrock TPI Base
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
TCI shift kit
Vette servo
B&M 3-4 upshift kit
TCI Trans Rebuild
2800 stall 9.5" TC
Nitto Drag radials
FUTURE MODS:
BEST RUN:
12.48 @ 109.23 MPH
I believe that they are longtubes, but am not sure what size, I was wondering this same thing last night. Also, I'd like to know how much ground clearance you give up when going to any of these full length headers...
But, another thing about the $79 Summit headers are that they are not of the highest quality, the flange thickness is real small, and you might have problems with exhaust leaks. But, if you don't have a problem cutting them up, a good way to stop the leaks is to cut the headers between the two inside ports and the outside ones, so they each basically bolt up seperately. Then cut the gaskets also.
Had this on my old 77 Camaro with cheap-o Flowtechs, and doubled up Mr. Gasket gaskets. I never had any problems with ex. leaks, but they were a little bit of a pain installing...
-Joel Likness
- 84 Z28 In Progress
Road Racer
- 85 S10 350/350
Drag Racer
- 85 Nissan 200SX (yes, it's Japanese)
Circle Track Car
- 91 Lumina 3.1 Euro
Daily Driver
-Joel Likness
Road Racer
- 85 S10 350/350
Drag Racer
Circle Track Car
Daily Driver
