Attn: Dan87Iroc-z
Old Apr 1, 2001 | 09:40 AM
twells's Avatar
Car: 1999 Tahoe LT 4x4
Engine: 5.7 Vortech 350
Transmission: 4L80E
Attn: Dan87Iroc-z
I removed the smog pump and i just left the black tube connected to the black pump but disconnected it from the smog pump. is this going to be o.k. or can i go ahead and remove the tube from the black box also?
Thanks TWELLS
Old Apr 1, 2001 | 05:34 PM
Dan87IROC-Z's Avatar
Since that tube isn't attached to anything, it isn't going to serve any purpose being there, so you might as well take it off. I would plug the part of the diverter valve box though so no debris from the road gets in there. Hope this helps!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
N.J.-SLICK-1
Aftermarket Product Review
Jul 31, 2014 09:15 AM
FatOldBastard
Jan 19, 2010 12:26 PM
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
90TA
Jan 20, 2003 09:05 PM
