just ordered earls header gaskets, but did I order the right ones please look.
Old Apr 15, 2001 | 08:41 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I have a gm 350 replacment motor, up to 1985 replacment, the gaskets I ordered whereear-29d03b from summit, they are 1.50 by 1.50 ports.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Apr 15, 2001 | 08:51 PM
BLACK Z's Avatar
Car: 86 Z28
I am also have edelbrock 1 5/8 headers for a lg4 305 on the car.
Old Apr 17, 2001 | 07:19 PM
Synergy's Avatar
Thos are way too big for your application. 1.50 by 1.50 is a very big port opening and you WILL have leaks. Take it back and get the next size down.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
1992 Trans Am
May 10, 2023 07:19 PM
92projectcamaro
Jan 18, 2016 08:00 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
hectre13
Sep 8, 2015 03:38 PM
