How do i get the cat off?
Old Apr 21, 2001 | 02:05 PM
Sweet_85_Bird's Avatar
Im only 16 and my grandpa would be like"what the hell are you doing that for"?I dont have access to a blow torch or anything like that.So how do i get it off?I guess i could go buy one if it came down to it.
Also,i have the stock muffler on mine and its a 2.8 and i wanna take the cat off.Would this sound ok with just the muffler or do i need to buy a dynomax
1985 Firechicken
2.8 v6
Mods:
TB Coolant Bypass
My own kik @$$ dual intake
Freshly Painted(bright metallic blue)
Mods to come:
Either an 80 series flows or super turbo dynomax.Cant decide!
An engine is like a person,to scream it has to exhale hard -Flowmaster
Old Apr 21, 2001 | 04:23 PM
dtpmike's Avatar
I am assuming you already have the bolts off. I had a hard time doing this too. The pipe goign into the cat was so tight that I had to use a hack saw and cut a diagnal cut across the overlapping cat pipe. Then I took a screw driver and bent the corners back. It was still very hard to get off, I have to twist it back and forth as I pulled on it. Then once I gutted it I put it back on and stick welded the slot closed because it was leaking.
Hope that helps.
89 camaro 305 tbi, flomaster 3 chamber cat back, gutted cat, Edlebrock open element, and a 160 degree T-stat. 2 kicker comp 12"'s, polk for the rest. Phoenix gold xs2300 to subs, kicker impulse 404XI to 4 speakers, pioneer DEH- P7000R head unit, and finally a 12 disc changer. Full leather interior from [URL=http://www.MrMikes.com[/URL](its nice)
TES Headers in the mail, and about to order a stage 2 fastchip.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
