need help please!!!
Old Jan 2, 2003 | 03:58 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
need help please!!!
Here it is. When i take off and start to accelerate there is a gurgling or knocking noise coming from the enging bay. It usually makes the noise when im accelerating and only when in gear. If i put it in neutral and rev the engine it sounds good. But when im accelerating it makes a loud almost like a deep gurgling sound. What can this be? Any ideas?
Old Jan 2, 2003 | 06:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I doubt it's the exhaust (you're on that forum, you know).
Is it a metallic, tinny sound? I'd check your ignition timing, as I suspect you've got pinging (that your knock sensor isn't able to take out).
Old Jan 2, 2003 | 06:28 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
What causes pinging, and how would you get rid of it?
Old Jan 2, 2003 | 06:49 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Usually bad timing, but it may be a bad knock sensor, or even the ESC module(Electronic spark control) is puking on you. I would try to re-set you timing and see if that helps any. Is the SES light on?? It won't make noise in park or neutural cause there isn't a load. I have found that even sometimes low tranny fluid can cause ping, or a bad tranny that is.
Old Jan 3, 2003 | 04:58 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
ocassionally the ses light will come on when highway driving and then go off again when stop and go driving.
