TES, best possible headers for my car?
Old May 12, 2001 | 04:56 PM
Yarnboy's Avatar
Don't SLP me..Unless you know someone with a $250 set they are out of the picture. Are Edelbrock's pretty much the best I can do? I need the A.I.R. tubes by the way. I always hear they are the easiest to put on and net the most gains. Thanks alot guys..
  • Red '88 IROC 305 TPI T-5 w/3.08
  • Accel 300+ Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Dual Friction Stage III Centerforce Clutch
  • Energy Suspension Transmission Mount
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Gutted Airboxes
  • Hypertech Stage II PROM
  • Hypertech Airfoil
  • Throttle Body Coolant Bypass
  • Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
Old May 12, 2001 | 05:20 PM
Dan87IROC-Z's Avatar
Yes, I agree, the TES headers would be the best you can get. I know lots of people who have them and are very happy. You can coat them if you want to, I didn't, but they still have a nice flat black finish to them after you wipe off the shipping paint soot.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old May 13, 2001 | 09:45 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its my opinion Edelcrock's are the worst. Dynomax, Hedman and Hooker are all better, and they're all a true 1 5/8" headers, instead of Edelcrock's stepped 1 1/2" headers.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 13, 2001 | 10:58 PM
Tas's Avatar
Tas
Edelbrocks "supposedly" aren't steped anymore, but since you are in florida and need no emissions, get the Hooker non-emissions super comps for $150. Or do dual exaust will full length headers.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old May 14, 2001 | 12:22 AM
camaroguy99's Avatar
I would seriously looking into either a stainless steel set of headers or at least coating the TES's considering the incredibly hummid enviroment you live in.
Old May 14, 2001 | 05:54 PM
Yarnboy's Avatar
I have heard many horror stories about fitting all the headers listed..I have heard of people gaining the most with TES and Mac headers..but Mac's dont fit well either. I am in FL for about a year..I still have MD tags..I will probably move back
  • Gutted Airboxes
  • Hypertech Airfoil
Old May 14, 2001 | 08:48 PM
85T\A's Avatar
I installed the TES on my car after I had them Jet Hot coated and had really no problems it's a tough job and takes some time
If you do get the TES do some grinding of the welds inside the tubes they leave a huge bead of weld in there....
85T\A 305 TPI Auto WS6 3:43 Edelbrock TES headers Jet Hot Coated,Air Foil,Hooker Cat Back,SFC's,B&M Mega Shifter
STB,AFPR,50000 org miles
1992 Trans Am
May 10, 2023 07:19 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
mustangman65_79
Aug 7, 2015 09:55 PM
