Worth it to coat the hedman's?
Old Jan 9, 2003 | 07:24 PM
RICHRAD's Avatar
like it says.. Just wondering if I should send my hedman shorty's off for a coat'in. Does the cost cover the Y-pipe too?
Old Jan 9, 2003 | 08:44 PM
BikertrashDude's Avatar
is it worth it? YES,
I never heard of anyone getting the Y-pipe coated though, it's not a usuall thing to do.
1) the headers will look better
2) they will perform better
3) they will last longer and not rust.
biker
Old Jan 9, 2003 | 09:55 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Is it worth it is up to you.
Me, after owning uncoated ones, I'm coating mine.
LIke said, they'll look better, last longer, more performance, less burnt wires, and will help protect the starter from heat.
I think Jet Hot includes coating the Y as well. check out www.jet-hot.com
Old Jan 9, 2003 | 10:09 PM
ctandc's Avatar
It's up to each person...
I've had headers coated, painted, and one pair I just dropped in with the crappy factory paint still on 'em...
As far as underhood temps are concerned, the only real difference I found is when having to work around the headers when the car is warm. The coated headers cooled off faster..
On the Hedman's I have in the IROC, I had them bead blasted, then initially coated them with some POR-20 I already had. The finish was a bit too bright for me, so I scuffed the POR-20 and used a can of alum colored VHT, then baked each header in the grill for about 30 minutes or so before installation.
I've had them in for right at month now, and they still look VERY good. I neglected to wrap them with something when installing them, so there are a couple of small grease stains on them.
I'll get some pics this weekend, as I just finished a water pump install, and this weekend I'm installing Taylor wires and centerbolt looms, painting the plenum / runners, and valve covers.
FWIW, the plug wires on the car are stock replacements that use 2 straight boots.....the closest one to the header tubes is tight only because it's straight boot, and even it isn't touching.
HTH
Old Jan 9, 2003 | 10:29 PM
Black91Z28's Avatar
Car: 1991 Camaro z28
Engine: 350 Tpi
Transmission: 700r4 Auto
yes, coat them!
Old Jan 10, 2003 | 12:20 AM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
Ceck out therml tech coatings www.thermaltechcoatings.com they will coat your headers inside and out for like $100.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
